[Armbian build PR] - Orange Pi 3 LTS: Fix ethernet broken for some users on 6.x kernel
Description
Fixes ethernet broken for some users on 6.x kernels. It was working fine for me on 6.x kernels. For @AGM1968, it was working fine only on cold boot, while for some users from forum it was not working at all. Hence this PR is raised to fix the same by increasing the startup frequency and specifying clock frequency for motorcomm chip
How Has This Been Tested?
  • [X] Tested by @AGM1968 and also by user on forum that this fixes the broken ethernet
  • [X] In my case, ethernet continues to work fine with this fix as it was working before.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
