I have Rock Pi S V13 and Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64.
When I change CPU settings (min frequency, max frequency, scaling governor) using armbian-config, the change works correctly as expected. However, these settings are lost on reboot. When I check the status of cpufrequtils service, it seems that it does not load correctly as it is not able to find the requested governor:
~$ systemctl status cpufrequtils.service
● cpufrequtils.service - LSB: set CPUFreq kernel parameters
     Loaded: loaded (/etc/init.d/cpufrequtils; generated)
     Active: active (exited) since Tue 2023-09-26 15:03:11 CEST; 18h ago
       Docs: man:systemd-sysv-generator(8)
    Process: 691 ExecStart=/etc/init.d/cpufrequtils start (code=exited, status=0/SUCCESS)
        CPU: 122ms
zář 26 15:03:10 labircam systemd[1]: Starting cpufrequtils.service - LSB: set CPUFreq kernel parameters...
zář 26 15:03:10 labircam cpufrequtils[691]: CPUFreq Utilities: Setting ondemand CPUFreq governor...disabled, governor not available...done.
zář 26 15:03:11 labircam systemd[1]: Started cpufrequtils.service - LSB: set CPUFreq kernel parameters.
But if I start it manually later, it seems to load all my settings correctly:
~$ sudo systemctl restart cpufrequtils
     Active: active (exited) since Wed 2023-09-27 09:04:44 CEST; 9s ago
    Process: 1968 ExecStart=/etc/init.d/cpufrequtils start (code=exited, status=0/SUCCESS)
        CPU: 123ms
zář 27 09:04:44 labircam systemd[1]: Starting cpufrequtils.service - LSB: set CPUFreq kernel parameters...
zář 27 09:04:44 labircam cpufrequtils[1968]: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...CPU2...CPU3...done.
zář 27 09:04:44 labircam systemd[1]: Started cpufrequtils.service - LSB: set CPUFreq kernel parameters.
Any ideas to fix the problem except manually reloading it later?
armbianmonitor: https://paste.armbian.com/owolufawif
So the reason for this problem is when "loadcpufreq" services loads CPU modules, it takes some time to load them. "cpufrequtils" is loaded right after and data in /sys/devices/system/cpu/cpu0/cpufreq don't have to exist yet. When I put "sleep 3" at the beginning of the /etc/init.d/cpufrequtils then the CPU settings are loaded correctly.
I don't see this load to early issue on any of my boards, perhaps it is specific to your board.
Please note that cpufrequtils is deprecated and has a number of issues with various boards that are unlikely to be addressed.
(the other issue with cpufrequtils not being enabled by default for all boards has been addressed).
I don't know but I fixed this issue by waiting for governor in /etc/init.d/cpufrequtils
check_governor_avail() {
        info="/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors"
        for i in $(seq 1 10); do
                if [ -f $info ]; then
                        break
                fi
                sleep 1
        done
        if [ -f $info ] && grep -q "\<$GOVERNOR\>" $info ; then
                return 0;
        fi
        return 1;
I'm not sure whether it is the correct solution, rather a workaround, especially when you don't have this problem.
Maybe the waiting should happen in "loadcpufreq", because it also checks for the governor existence before its end and reports that "none" CPU module was loaded.
