[Armbian build PR] - cli: add command to rewrite/refresh kernel configs
Description
Adding a command that can be used to refresh kernel configs without launching menuconfig interface. This can be helpful to refresh kernel configs when doing kernel upgrades for all kernels being bumped by running in a for loop and can be also be used in some automation to periodically refresh kernel configs
How Has This Been Tested?
  • [X] Tested by running ./compile.sh BOARD=khadas-vim4 BRANCH=legacy rewrite-kernel-config. It refreshed and updated config/kernel/linux-meson-s4t7-legacy.config file based on the needed updates which in this case was mostly compiler and toolchain versions as this file has not been refreshed for sometime now.
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
