RSS Bot Posted October 6, 2023 Posted October 6, 2023 Description This fixes montior not working after its turned off and on again. This also helps getting the monitors working that doesn't work by default by setting hdmimode=1080p60hz and outputmode=1080p60hz in boot/armbianEnv.txt file. The fix is based on hdmitx21 commit used on vim4. The same change was missing for hdmitx20 that is used on vim1s. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [X] Tested on vim1s. Monitor hotplug works. Non-working monitor now works with manual configuration Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
