Hi everyone!
I am struggling with audio input.
Output audio from LINEOUT pins works fine out-of-the-box!
What about the audio input?
To begin with I have tested the arecord command with these error messages…
TEST 1
root@rockpi-s:~# arecord -f S16_LE -d 10 -r 16000 --device=“hw:0,0” test-mic.wav
Recording WAVE ‘test-mic.wav’ : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
arecord: set_params:1358: Channels count non available
TEST 2
root@rockpi-s:~# arecord -f S16_LE -c 2 -d 10 -r 16000 --device=“hw:0,0” test-mic.wav
Recording WAVE ‘test-mic.wav’ : Signed 16 bit Little Endian, Rate 16000 Hz, Stereo
arecord: set_params:1416: Unable to install hw params:
ACCESS: RW_INTERLEAVED
FORMAT: S16_LE
SUBFORMAT: STD
SAMPLE_BITS: 16
FRAME_BITS: 32
CHANNELS: 2
RATE: 16000
PERIOD_TIME: 125000
PERIOD_SIZE: 2000
PERIOD_BYTES: 8000
PERIODS: 4
BUFFER_TIME: 500000
BUFFER_SIZE: 8000
BUFFER_BYTES: 32000
TICK_TIME: 0
Any suggestions?
Posted (edited)
Hi again!
Todays update:
When doing the dmesg command it returns the following below.
How to interpret these error messages?
root@rockpi-s:~# dmesg
[  375.793438] rockchip-i2s-tdm ff320000.i2s: ASoC: error at snd_soc_dai_hw_params on ff320000.i2s: -22
[  375.793546]  ff320000.i2s-rk3308-hifi: ASoC: error at __soc_pcm_hw_params on ff320000.i2s-rk3308-hifi: -22
Edited by danj
