RSS Bot Posted October 9, 2023 Posted October 9, 2023 Bumps ossf/scorecard-action from 2.2.0 to 2.3.0. Release notes Sourced from ossf/scorecard-action's releases. v2.3.0 What's Changed :seedling: Bump github.com/ossf/scorecard/v4 from v4.11.0 to v4.13.0 by @spencerschrock in ossf/scorecard-action#1270 For a full changelist of what this includes, see the v4.12.0 and v4.13.0 release notes :sparkles: Send rekor tlog index to webapp when publishing results by @spencerschrock in ossf/scorecard-action#1169 :bug: Prevent url clipping for GHES instances by @rajbos in ossf/scorecard-action#1225 Documentation :book: Update access rights needed to see the results in code scanning by @rajbos in ossf/scorecard-action#1229 :book: Add package comments. by @spencerschrock in ossf/scorecard-action#1221 :book: Add SECURITY.md file by @david-a-wheeler in ossf/scorecard-action#1250 :book: Fix typo in token input docs by @aabouzaid in ossf/scorecard-action#1258 New Contributors @david-a-wheeler made their first contribution in ossf/scorecard-action#1250 @aabouzaid made their first contribution in ossf/scorecard-action#1258 Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.2.0...v2.3.0 Commits 483ef80 :seedling: Bump docker tag for v2.3.0 release. (#1271) 5d35913 :seedling: Bump github.com/ossf/scorecard/v4 from v4.11.0 to v4.13.0 (#1270) 49787a6 :seedling: Bump distroless/base from 46c5b9b to a35b652 (#1269) 4283c75 :seedling: Bump github/codeql-action from 2.21.8 to 2.21.9 (#1268) 709ecd0 :seedling: Bump golang from 6974950 to c416cee (#1266) 25bb02c :seedling: Bump actions/checkout from 4.0.0 to 4.1.0 (#1267) b687393 :seedling: Bump github/codeql-action from 2.21.5 to 2.21.8 (#1265) 6a1c21f :seedling: Bump golang from cffaba7 to 6974950 (#1264) 2dee8c1 :seedling: Bump github.com/sigstore/cosign/v2 from 2.1.1 to 2.2.0 (#1254) e79dcb6 :seedling: Upgrade to go 1.20 (#1262) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
