RSS Bot Posted October 11, 2023 Posted October 11, 2023 v2: arch: arm64: dts: amlogic: meson-g12b-waveshare-cm4-io-base-b Fan, RTC and USB support RTC requires rtc pcf85063 driver Fan requires hwmon emc2305 driver (new addition) hwmon: emc2305: fixups for driver The driver had a number of issues, checkpatch warnings/errors, and other limitations, so fix these up to make it usable. Additional: hwmon: emc2305: Change OF properties pwm-min & pwm-max to u8 hwmon: emc2305: Add calls to initialize cooling maps How was it tested? Built a new image with the following changes and booted to make sure it works as it should. Inactive: == Waveshare CM4-IO-BASE-B with BPI-CM4 Module (6.1.57-current-meson64) CPU usage: 0 Processors: Cortex-A53 @ 2016MHz 51°C, Cortex-A73 @ 2400MHz 53°C Cur freq: 1000MHz 2400MHz Fan: 0 RPM (0) <-- FAN INACTIVE Online: 0-5 Governor: ondemand Memory: 3.7G 331M Entropy: 256 Uptime: 14:12:26 up 18 min, 4 users, load average: 0.01, 0.24, 0.31 Active: == Waveshare CM4-IO-BASE-B with BPI-CM4 Module (6.1.57-current-meson64) CPU usage: 90 Processors: Cortex-A53 @ 2016MHz 82°C, Cortex-A73 @ 2400MHz 82°C Cur freq: 2016MHz 2400MHz Fan: 3368 RPM (255) <-- FAN ACTIVE Online: 0-5 Governor: ondemand Memory: 3.7G 430M Entropy: 256 Uptime: 14:19:09 up 25 min, 4 users, load average: 1.76, 1.06, 0.64 NOTE: The temps are not as they should be as they sent me a 12V instead of a 5V fan. I decided to keep the 12V to do the testing with, as I wait for the 5V to arrive. The difference between them shouldn't change the basic functionality, only the quality of the cooling. Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
