[Armbian build PR] - thinkpad-x13s: bump to 6.6-rcX; support trixie/sid/mantis userspace sans PPA
  • partitioning: efi: introduce UEFI_MOUNT_POINT_SKIP_FSTAB, if set to yes, skips /etc/fstab entry for the ESP
    • sometimes we just don't want the ESP listed in the fstab, otherwise works the same
  • thinkpad-x13s: bump to 6.6-rcX; support trixie/sid/mantis userspace sans PPA
    • This requires https://github.com/armbian/firmware/pull/65
    • thinkpad-x13s: workaround ubuntu's pd-mapper only starting on "-laptop" kernels
    • thinkpad-x13s: add fprintd and pam
    • thinkpad-x13s: throws warnings about missing userspace if not trixie/sid/mantic
    • thinkpad-x13s: split hooks into functions
    • thinkpad-x13s: enable touchscreen hack via udev
    • thinkpad-x13s: use override, not separate service, for systemd settage of BT public-addr
    • thinkpad-x13s: "handle" alsa-ucm-conf by simply overwriting with fixed version
    • thinkpad-x13s: update .config
    • thinkpad-x13s: bump to 6.6-rc4; add more cmdline params
      • add a bunch of tricks I learned from jhovold's talk
      • update .config, no changes
    • thinkpad-x13s: bump to steev's lenovo-x13s-v6.6.0-rc5 - update .config, no changes
    • thinkpad-x13s: trixie is missing fprintd/libpam-fprintd, skip for now if trixie
    • thinkpad-x13s: set UEFI_MOUNT_POINT_SKIP_FSTAB=yes (otherwise hangs waiting for it, dunno why)
View the full article
