RSS Bot Posted October 30, 2023 Posted October 30, 2023 Bumps ossf/scorecard-action from 2.3.0 to 2.3.1. Release notes Sourced from ossf/scorecard-action's releases. v2.3.1 What's Changed :seedling: Bump github.com/ossf/scorecard/v4 from v4.13.0 to v4.13.1 by @spencerschrock in ossf/scorecard-action#1282 Adds additional Fuzzing detection and fixes a SAST bug related to detecting CodeQL. For a full changelist of what this includes, see the v4.13.1 release notes Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.3.0...v2.3.1 Commits 0864cf1 :seedling: Bump docker tag to for v2.3.1 release (#1284) 72df3bf :seedling: Bump github.com/ossf/scorecard/v4 from v4.13.0 to v4.13.1 (#1282) 0ea411f :seedling: Bump the docker-images group with 1 update (#1281) dbfd042 :seedling: Bump the github-actions group with 1 update (#1280) 2fa1e2f :seedling: Bump golang.org/x/net from 0.16.0 to 0.17.0 (#1278) 652ddd0 :seedling: Bump github.com/google/go-cmp from 0.5.9 to 0.6.0 (#1277) 28d0c92 :seedling: Group Dependabot updates for GitHub Actions and Dockerfiles (#1276) cb50491 :seedling: Bump distroless/base from a35b652 to b31a6e0 (#1275) 87157ac :seedling: Bump github/codeql-action from 2.21.9 to 2.22.1 (#1274) 7c1648b :seedling: Bump step-security/harden-runner from 2.5.1 to 2.6.0 (#1273) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
