RSS Bot Posted October 30, 2023 Share Posted October 30, 2023 Bumps tj-actions/changed-files from 39 to 40. Release notes Sourced from tj-actions/changed-files's releases. v40 Changes in v40.0.0 🔥 🔥 Breaking Change 🔥 🔥 Directory patterns now require explicit specification of the globstar pattern to match all sub paths. ... - name: Get specific changed files id: changed-files-specific uses: tj-actions/changed-files@v40 with: files: | - dir + dir/** What's Changed Upgraded to v39.2.4 by @tj-actions-bot in tj-actions/changed-files#1664 chore(deps): lock file maintenance by @renovate in tj-actions/changed-files#1665 Bump @types/node from 20.8.7 to 20.8.8 by @dependabot in tj-actions/changed-files#1666 chore(deps): update dependency @types/node to v20.8.9 by @renovate in tj-actions/changed-files#1668 remove: appending globstar pattern for directories to prevent bugs with path matching by @jackton1 in tj-actions/changed-files#1670 chore(deps): lock file maintenance by @renovate in tj-actions/changed-files#1671 Full Changelog: https://github.com/tj-actions/changed-files/compare/v39...v40.0.0 v40.0.0 🔥 🔥 Breaking Change 🔥 🔥 Directory patterns now require explicit specification of the globstar pattern to match all sub paths. ... - name: Get specific changed files id: changed-files-specific uses: tj-actions/changed-files@v40 with: files: | - dir + dir/** What's Changed ... (truncated) Changelog Sourced from tj-actions/changed-files's changelog. Changelog 40.0.0 - (2023-10-26) 📦 Bumps Bump @types/node from 20.8.7 to 20.8.8 (#1666) Signed-off-by: dependabot[bot] support@github.com Co-authored-by: dependabot[bot] (955cdc8) - (dependabot[bot]) ➕ Add Added missing changes and modified dist assets. (af292f1) - (GitHub Action) Added missing changes and modified dist assets. (e48cacb) - (GitHub Action) ➖ Remove Appending globstar pattern for directories to prevent bugs with path matching (#1670) (3ce5a29) - (Tonye Jack) ⚙️ Miscellaneous Tasks deps: Lock file maintenance (2ddcb04) - (renovate[bot]) Update test.yml (d898dd0) - (Tonye Jack) deps: Update dependency @types/node to v20.8.9 (0e08afd) - (renovate[bot]) deps: Lock file maintenance (5aee572) - (renovate[bot]) ⬆️ Upgrades Upgraded to v39.2.4 (#1664) Co-authored-by: jackton1 jackton1@users.noreply.github.com (c83cb31) - (tj-actions[bot]) 39.2.4 - (2023-10-23) ➕ Add Added missing changes and modified dist assets. (28cf220) - (GitHub Action) Added missing changes and modified dist assets. (40e81cc) - (GitHub Action) ⚙️ Miscellaneous Tasks deps: Update typescript-eslint monorepo to v6.9.0 (fea790c) - (renovate[bot]) deps: Update actions/setup-node action to v4 (#1662) (794c26f) - (renovate[bot]) deps: Update actions/setup-node action to v3.8.2 (0f6525c) - (renovate[bot]) deps: Lock file maintenance (faedee1) - (renovate[bot]) ... (truncated) Commits af292f1 Added missing changes and modified dist assets. 2ddcb04 chore(deps): lock file maintenance 3ce5a29 remove: appending globstar pattern for directories to prevent bugs with path ... d898dd0 chore: Update test.yml 0e08afd chore(deps): update dependency @types/node to v20.8.9 955cdc8 Bump @types/node from 20.8.7 to 20.8.8 (#1666) e48cacb Added missing changes and modified dist assets. 5aee572 chore(deps): lock file maintenance c83cb31 Upgraded to v39.2.4 (#1664) See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article Link to comment Share on other sites More sharing options...
