[Armbian build PR] - xiaomi-elish: update config for 6.6, and fix one bluetooth pairing issue
Description
Enable BINFMT_MISC for box86. Enable UHID for bluetooth LE keyboard I have a bluetooth LE keyboard with pairing issue:
unexpected SMP command 0x06
unexpected SMP command 0x07
The root cause might be a race condition, but the kernel patch which just pass two SMP code check just works.
How Has This Been Tested?
  • [x] xiaomi-elish kernel build success
  • [x] My bluetooth keyboard is paired and work fine.
Checklist:
  • [ ] I have made corresponding changes to the documentation
P.S.:
@igorpecovnik it's my bad to push the branch to the main repo, this pr is from my own repo so you can delete that branch if necessary: https://github.com/armbian/build/tree/sm8250-6.6-config
View the full article
