[Armbian build PR] - fix: meson-g12b: blacklist simpledrm kernel module, as it conflicts with panfrost
Description
This is a follow-up of: https://github.com/armbian/build/pull/5901 It resolves a conflict between the SimpleDRM and Panfrost graphic drivers by blacklisting simpledrm.
Other boards of the same family are assumed to have the same issue and will probably benefit from this fix as well. However, the fix has been actually tested only on the Khadas VIM3. I cannot test this change for other boards, as I do not own them.
The Banana Pi M5 was also included for this change, because the driver conflict has also been mentioned in another Jira ticket. Note that this board is of the meson-sm1 family!
How Has This Been Tested?
Perhaps someone else has these boards available for testing?
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [X] I have commented my code, particularly in hard-to-understand areas
  • [N/A] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
  • [N/A] Any dependent changes have been merged and published in downstream modules
View the full article
