[Armbian build PR] - config: boards: thead: enable pwm-fan support default
Description
For lichee-pi 4A has pwm-fan node in devicetree such as:
 fan: pwm-fan {
 compatible = "pwm-fan";
  #cooling-cells = <2>;
  pwms = <&pwm 1 10000000 0>;
  cooling-levels = <0 64 192 255>;
So enable pwm-fan support default with licheepi-4a. And I test it's worked on my licheepi 4a board with 8GB ddr.
Jira reference number [AR-9999]
How Has This Been Tested?
  • [x] Test on licheepi 4A board with 8GB ddr
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
