[Armbian build PR] - tritium-h5: Change to using Armbian default DRAM CLK value using hook
Description
Converting #5898 to use hook instead of patch
How Has This Been Tested?
  • [X] U-boot compiles. Also .config shows 648 as the default dram clk value.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
