RSS Bot Posted November 18, 2023 Posted November 18, 2023 Description WireGuard support got lost with one of the recent changes to the Odroid XU4 kernel config. This commit re-adds it as module. Jira reference number [AR-9999] How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Kernel built with lastest Armbian main branch + this change [x] Tested on Odroid XU4Q with an actual WireGuard server test installation root@OdroidXU4:~# dpkg -l linux-image-current-odroidxu4 ii linux-image-current-odroidxu4 23.11.0-trunk armhf Armbian Linux current kernel image 6.1.61-current-odroidxu4 root@OdroidXU4:~# uname -a Linux OdroidXU4 6.1.61-current-odroidxu4 #1 SMP PREEMPT Tue Nov 7 20:10:43 UTC 2023 armv7l GNU/Linux root@OdroidXU4:~# wg interface: wg0 public key: xxxx private key: (hidden) listening port: 51820 peer: xxxx allowed ips: 10.9.0.2/32 Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
