[Armbian build PR] - Allwinner: bump legacy, current and edge kernels
Description
Bumped Allwinner kernels.
legacy - 5.15.137 -> 5.15.139 current - 6.1.62 -> 6.1.63 edge - 6.6.1 -> 6.6.2
Updated ov5640 camera patches to fix patch application failure. Also rebased the config files.
How Has This Been Tested?
  • [X] Both 32-bit and 64-bit kernel builds fine.
  • [X] Tested 32-bit kernel on NanoPi Duo2(H3). All 3 kernels seems to work fine.
  • [X] Tested ov5640 camera with current and edge kernels. Autofocus didn't worked for me, but its possible that I might have damaged my camera by placing something on it. Have to retest with an older kernel later to make sure. But video capture worked fine.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
