Hi, I've been trying out the jammy image for the raspberry pi. (Raspberry pi 4b)
I found a problem with the display settings.
I am using a Dell display of 1440x900
In the display settings it show the right monitor and the correct settings but the actual display shows a 5cm black band at the right-hand side.
And whatever I do makes no difference
Anyone have an answer?
Edited by Rein
change of expression
Hi Gunjan. The config.txt file does not have that line. I tried adding the line to the end of the config.txt file but this has not resolved the issue.
Thanks for your reply anyway.
Edited by Rein
correction
Here is  a photo of my problem.
The system has discovered the right display settings but the actual display is wrong.
Another thing that may be related (?) : Every few seconds the display goes blank momentarily.
I am running a web page. I have a choice of a number of OSs on ssd cards (Debian , Ubuntu). They all work correctly on same video display and same cable 😊.
