enredar Posted January 2, 2017 Posted January 2, 2017 First of all sorry for my bad english and my limited knoledge of linux. After run apt-get update // apt-get upgrade my Bpi didin´t share folders over samba. Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these. The following packages have unmet dependencies: python-samba : Depends: samba-libs (= 2:4.2.10+dfsg-0+deb8u3) but 2:4.2.14+dfsg-0+deb8u2 is installed E: Unmet dependencies. Try using -f. banana@bananapi:~$ When I put the command apt-get -f install the console returns this banana@bananapi:~$ sudo apt-get -f install [sudo] password for banana: Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following extra packages will be installed: python-samba The following packages will be upgraded: python-samba 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 3 not fully installed or removed. Need to get 0 B/861 kB of archives. After this operation, 9.216 B of additional disk space will be used. Do you want to continue? [Y/n] Type the Y and get this Do you want to continue? [Y/n] y (Reading database ... 59900 files and directories currently installed.) Preparing to unpack .../python-samba_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb ... Traceback (most recent call last): File "/usr/bin/pyclean", line 25, in <module> import optparse File "/usr/lib/python2.7/optparse.py", line 90, in <module> from gettext import gettext File "/usr/lib/python2.7/gettext.py", line 49, in <module> import locale, copy, os, re, struct, sys File "/usr/lib/python2.7/struct.py", line 1, in <module> from _struct import * ValueError: module functions cannot set METH_CLASS or METH_STATIC dpkg: warning: subprocess old pre-removal script returned error exit status 1 dpkg: trying script from the new package instead ... Traceback (most recent call last): File "/usr/bin/pyclean", line 25, in <module> import optparse File "/usr/lib/python2.7/optparse.py", line 90, in <module> from gettext import gettext File "/usr/lib/python2.7/gettext.py", line 49, in <module> import locale, copy, os, re, struct, sys File "/usr/lib/python2.7/struct.py", line 1, in <module> from _struct import * ValueError: module functions cannot set METH_CLASS or METH_STATIC dpkg: error processing archive /var/cache/apt/archives/python-samba_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb (--unpack): subprocess new pre-removal script returned error exit status 1 Traceback (most recent call last): File "/usr/bin/pycompile", line 27, in <module> import optparse File "/usr/lib/python2.7/optparse.py", line 90, in <module> from gettext import gettext File "/usr/lib/python2.7/gettext.py", line 49, in <module> import locale, copy, os, re, struct, sys File "/usr/lib/python2.7/struct.py", line 1, in <module> from _struct import * ValueError: module functions cannot set METH_CLASS or METH_STATIC dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: /var/cache/apt/archives/python-samba_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) banana@bananapi:~$ So I think to remove entire samba and this is what i get banana@bananapi:~$ sudo apt-get purge samba Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: python-samba : Depends: samba-libs (= 2:4.2.10+dfsg-0+deb8u3) but 2:4.2.14+dfsg-0+deb8u2 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). banana@bananapi:~$ I´m stuck and I don´t know how to solve this, can you give me any help or advice. Thanks
