[Armbian build PR] - xiaomi-elish: add typec pd support
Description
Xiaomi Pad 5 pro is using pm8150b to support typec pd with volt up to 13.2V and current up to 6A, so I set the max negotiation to 12V5A.
How Has This Been Tested?
  • [x] xiaomi-elish kernel build success
  • [x] I can negotiate 12V2A.
$ sensors tcpm_source_psy_c440000.spmi:pmic@2:typec@1500-isa-0000
Adapter: ISA adapter
in0:          12.00 V  (min = +12.00 V, max = +12.00 V)
curr1:         2.00 A  (max =  +2.00 A)
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
