[Armbian build PR] - kernel: sunxi: current: fix booting with 6.1.64 kernel
Description
Enabled CONFIG_RCU_TRACE as a workaround to fix booting 6.1.64 kernel on 32-bit allwinner boards. Edge kernel is not having this issue and hence workaround was not added for the same.
How Has This Been Tested?
  • [X] Booted on Orange Pi Zero (sun8i H3)
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
