[Armbian build PR] - Orange Pi Zero: Enable crust and fix suspend/resume
Description
Enabled crust for Orange Pi Zero. Also added workaround to make sure board does resume successfully after sleep. The xradio_wlan driver seems to interfere with the same causing board to get stuck on resume after its put to sleep. Hence now we unload the module when entering sleep and reload it on resume. This works with systemctl suspend, but is still broken with rtcwake.
Jira reference number AR-1918
How Has This Been Tested?
  • [X] Tested suspend/resume works using echo +20 > /sys/class/rtc/rtc0/wakealarm && systemctl suspend
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
