RSS Bot Posted December 4, 2023 Posted December 4, 2023 Bumps actions/labeler from 4 to 5. Release notes Sourced from actions/labeler's releases. v5.0.0 What's Changed This release contains the following breaking changes: The ability to apply labels based on the names of base and/or head branches was added (#186 and #54). The match object for changed files was expanded with new combinations in order to make it more intuitive and flexible (#423 and #101). As a result, the configuration file structure was significantly redesigned and is not compatible with the structure of the previous version. Please read the action documentation to find out how to adapt your configuration files for use with the new action version. The bug related to the sync-labels input was fixed (#112). Now the input value is read correctly. By default, dot input is set to true. Now, paths starting with a dot (e.g. .github) are matched by default. Version 5 of this action updated the runtime to Node.js 20. All scripts are now run with Node.js 20 instead of Node.js 16 and are affected by any breaking changes between Node.js 16 and 20. For more information, please read the action documentation. New Contributors @joshdales made their first contribution in actions/labeler#203 @dusan-trickovic made their first contribution in actions/labeler#626 @sungh0lim made their first contribution in actions/labeler#630 @TrianguloY made their first contribution in actions/labeler#629 Full Changelog: https://github.com/actions/labeler/compare/v4...v5.0.0 v5.0.0-beta.1 What's Changed In scope of this beta release, the structure of the configuration file (.github/labeler.yml) was changed from LabelName: - any: - changed-files: ['list', 'of', 'globs'] - base-branch: ['list', 'of', 'regexps'] - head-branch: ['list', 'of', 'regexps'] - all: - changed-files: ['list', 'of', 'globs'] - base-branch: ['list', 'of', 'regexps'] - head-branch: ['list', 'of', 'regexps'] to LabelName: - any: - changed-files: - AnyGlobToAnyFile: ['list', 'of', 'globs'] - AnyGlobToAllFiles: ['list', 'of', 'globs'] - AllGlobsToAnyFile: ['list', 'of', 'globs'] - AllGlobsToAllFiles: ['list', 'of', 'globs'] - base-branch: ['list', 'of', 'regexps'] - head-branch: ['list', 'of', 'regexps'] - all: - changed-files: - AnyGlobToAnyFile: ['list', 'of', 'globs'] - AnyGlobToAllFiles: ['list', 'of', 'globs'] - AllGlobsToAnyFile: ['list', 'of', 'globs'] </tr></table> ... (truncated) Commits 8558fd7 Merge pull request #709 from actions/v5.0.0-beta 000ca75 Merge pull request #700 from MaksimZhukov/apply-suggestions-and-update-docume... cb66c2f Update dist 9181355 Apply suggestions for the beta vesrion and update the documentation efe4c1c Merge pull request #699 from MaksimZhukov/update-node-runtime-and-dependencies c0957ad Run Prettier 8dc8d18 Update Node.js version in reusable workflows d0d0bbe Update documentation 1375c42 5.0.0 ab7411e Change version of Node.js runtime to node20 Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
