Hi There,
 I would like to run Linux5 or Linux6 on Jetson nano, display using HDMI-DVI adapter. It worked fine with Jetpack4 (=Linux4).
When I boot with armbian/Linux5.10, which is linux-image-current-jetson-nano, the display tells me it is out of sync then I would force the display as 1280x1024@60Hz, since it looks like Linux fb or X11 are trying to use 1280x1024@75Hz, so that I need edid/1280x1024.bin (maybe with video=1280x1024@60) using {linux-source}/tools/edid to maintain the resolution and sync.
I tried both of gcc-10 and gcc-9 to build it, but failed with below error:
edid.S: Assembler messages:
edid.S:274: Error: cannot represent BFD_RELOC_8 relocation in this object file format
Any workaround? or is this plan never work?
Thank you.
