Juriom Posted December 5, 2023 Posted December 5, 2023 Hello , looking to upgrade from SBC Rock64 to RockPro64< however, on the homepage it is mentioned, that https://wiki.pine64.org/wiki/ROCKPro64_Software_Releases Quote If you are booting from a Micro SD card, then both Linux kernel versions will work. If you are trying to boot from an eMMC module then the 4.4.y will work, but the newer 5.10.y will not. Since my Rock64 is running aready Linux kernel 4.4 and i am looking to upgrade, both from Rock64 and from SDcard to eMMC, my question, if this limitation still applies to RockPro64 with newer editions of Armbian, also since there is no mention of it on the official Armbian Page for RockPro64 https://www.armbian.com/rockpro64/ Thank you very much 0 Quote
prahal Posted January 12, 2024 Posted January 12, 2024 @Juriom might be related to the hs400es issue from mainline 0 Quote
