Stefan2016 Posted January 7, 2017 Posted January 7, 2017 Hello, sorry if this might seem stupid.I have an Orange Pi Zero Board. I have an armbian running on it (jesse). I have an usb-wifi-adapter connected to the onboard-usb-jack. 'lsusb' sais: Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 002: ID 0bda:8172 Realtek Semiconductor Corp. RTL8191SU 802.11n WLAN Adapter Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub I cannot see the device by typing "ifconfig -a" wlan0 is shown (onboard-wifi), but where`s my expected wlan1 ? I tried: "apt-get install firmware-realtek", but it sais: Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: firmware-realtek 0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded. Need to get 0 B/208 kB of archives. After this operation, 719 kB of additional disk space will be used. (Reading database ... 43669 files and directories currently installed.) Preparing to unpack .../firmware-realtek_0.43_all.deb ... Unpacking firmware-realtek (0.43) ... dpkg: error processing archive /var/cache/apt/archives/firmware-realtek_0.43_all.deb (--unpack): trying to overwrite '/lib/firmware/RTL8192SU/rtl8192sfw.bin', which is also in package armbian-firmware 5.24 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/firmware-realtek_0.43_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) What am I missing?
