RSS Bot Posted December 8, 2023 Posted December 8, 2023 Original version destroyed journal on command postrotate as files in /var/log.hdd/journal are overwritten by cat. With the patch journal is not damaged anymore. Description In original version in postrotate files in /var/log.hdd/journal are deleted by the command dest="/var/log/$file" cat $file > $dest as /var/log/journal is a symling to /var/log.hdd/journal files are cated on themselves which ends up with an empty file. How Has This Been Tested? check journal by journactl. There is no data earlier than today 0:00. Also "journalctl --verify" shows that journal is damaged. Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
