[Armbian build PR] - Use extension lima serverflags
Description
The "optional/boards" directory seems to have been deprecated and actually never used so much. Remove the last board support package there (rk3318-box) and move into extension as suggested by @rpardini. Ancillary BSP files have been removed too.
The extension may have global interest because it was a workaround for X.Org and Lima driver: the former was not able to autodetect the latter with some revision combinations. That configuration fixes the autodetection.
At the moment, it has been enabled in rk3318-box board and rk322x family.
How Has This Been Tested?
  • [x] Compile debian bookworm image for rk3318-box and verify 40-serverflags.conf presence
  • [x] Compile debian bookworm image for rk322x-box and verify 40-serverflags.conf presence
Checklist:
  • [x] My code follows the style guidelines of this project
  • [x] I have performed a self-review of my own code
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] My changes generate no new warnings
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
