[Armbian build PR] - Orangepizero2: Add wifi support for current and edge kernels
Description
This should get wifi working on OrangePi Zero2 on current and edge kernel
How Has This Been Tested?
  • [X] Not tested as I don't have the device. @AGM1968 Could you please test the same?
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
