[Armbian build PR] - rk3318: add uboot Recovery button support
Description
Add uboot 'button' cmd and add Recovery button to rk3318 uboot dts.
In the linux kernel dts button is labeled lowercase "recovery", but I've chosen "Recovery" as it is more frequent in uboot dts'es:
$ (cd cache/sources/u-boot-worktree/u-boot/v2022.07/arch/arm/dts; grep -ir 'label.*"recovery"' .)
./rk3399-nanopc-t4.dts:                 label = "Recovery";
./rk3399-khadas-edge.dtsi:                      label = "Recovery";
./rk3399-roc-pc.dtsi:                   label = "Recovery";
./rk3328-rock-pi-e.dts:                 label = "Recovery";
./rk3066a-mk808.dts:                    label = "recovery";
./rk3399-nanopi-m4b.dts:                        label = "Recovery";
How Has This Been Tested?
  • [x] boot rk3318 with modified uboot.cmd to test new command:
if button Recovery; then
    echo "Recovery ON"
else
    echo "Recovery OFF"
fi
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
