[Armbian build PR] - build(deps): bump github/codeql-action from 2 to 3
Bumps github/codeql-action from 2 to 3.
Release notes
Sourced from github/codeql-action's releases.
CodeQL Bundle v2.15.4
Bundles CodeQL CLI v2.15.4
Includes the following CodeQL language packs from github/codeql@codeql-cli/v2.15.4:
CodeQL Bundle
Bundles CodeQL CLI v2.15.3
Includes the following CodeQL language packs from github/codeql@codeql-cli/v2.15.3:
CodeQL Bundle
Bundles CodeQL CLI v2.15.2
Includes the following CodeQL language packs from github/codeql@codeql-cli/v2.15.2:
... (truncated)
Changelog
Sourced from github/codeql-action's changelog.
Commits
  • 3a9f6a8 update javascript files
  • cc4fead update version in various hardcoded locations
  • 183559c Merge branch 'main' into update-bundle/codeql-bundle-v2.15.4
  • 5b52b36 reintroduce PR check that confirm action can be still be compiled on node16
  • 5b19bef change to node20 for all actions
  • f2d0c2e upgrade node type definitions
  • d651fbc change to node20 for all actions
  • 382a50a Merge pull request #2021 from github/mergeback/v2.22.9-to-main-c0d1daa7
  • 458b422 Update checked-in dependencies
  • 5e0f9db Update changelog and version after v2.22.9
  • See full diff in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
