[Armbian build PR] - Fixup compilation helios64 uboot
Description
Fix compilation warnings
[🐳|πŸ”¨]     CC      arch/arm/mach-rockchip/boot_mode.o
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c: In function β€˜rockchip_dnl_mode_check’:
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c:174:24: warning: β€˜return’ with a value, in function returning void [-Wreturn-type]
[🐳|πŸ”¨]     174 |                 return 0;
[🐳|πŸ”¨]         |                        ^
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c:166:6: note: declared here
[🐳|πŸ”¨]     166 | void rockchip_dnl_mode_check(void)
[🐳|πŸ”¨]         |      ^~~~~~~~~~~~~~~~~~~~~~~
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c:183:24: warning: β€˜return’ with a value, in function returning void [-Wreturn-type]
[🐳|πŸ”¨]     183 |                 return 0;
[🐳|πŸ”¨]         |                        ^
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c:196:17: warning: implicit declaration of function β€˜cli_simple_run_command’ [-Wimplicit-function-declaration]
[🐳|πŸ”¨]     196 |                 cli_simple_run_command(cmd, 0);
[🐳|πŸ”¨]   arch/arm/mach-rockchip/boot_mode.c:170:13: warning: unused variable β€˜ret’ [-Wunused-variable]
[🐳|πŸ”¨]     170 |         int ret = 0;
[🐳|πŸ”¨]         |             ^~~
it could be that adding the missing cli include fix functionality. So this patch might be more than cosmetic.
How Has This Been Tested?
  • [ x ] compile u-boot for helios64 board (v2022.07) and boot with this u-boot. -./compile.sh uboot BOARD=helios64 BRANCH=edge RELEASE=bookworm BUILD_KSRC=no ARTIFACT_IGNORE_CACHE="yes"
The CONFIG_SYS_SCSI_MAX_DEVICE definition removal from u-boot v2022.04 (as since this version this is a macro) I have only build tested with: ./compile.sh uboot BOARD=helios64 BRANCH=edge RELEASE=bookworm BUILD_KSRC=no ARTIFACT_IGNORE_CACHE="yes" BOOTBRANCH="tag:v2022.04" BOOTPATCHDIR="u-boot-rockchip64-v2022.04"
Checklist:
  • [ x ] My code follows the style guidelines of this project
  • [ x ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ x ] My changes generate no new warnings
  • [ x ] Any dependent changes have been merged and published in downstream modules
View the full article
Γ—
Γ—
