[Armbian build PR] - Helios64: the chip temperature sensor is really a National lm75
Description
The lm75 sensor was defined in the dts as "onnn,lm75". Set it to "national,lm75" as is set in the upstream dts. (there is no such thing as "onnn,lm75").
Later on (or maybe I should include it there) we should remove the lm75 module from MODULES and MODULES8lEGACY in config/boards/helios64.csc, as the DTS already loads it. (which makes me think "onnn,lm75" as a DTS node never was recognized by a kernel, thus the need to explicitly load lm75).
How Has This Been Tested?
  • [x] remove lm57 from the config (I believe it was /etc/modules but is long gone) and reboot with new dts
Checklist:
  • [ ] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
