Unable to connect to WIFI on rk3318 even though WIFI SSID is listed otherwise unstable WIFI
New to armbian, I have a H96Max Android TV Box, Initially I flashed it with Armbian_23.11.1_Rock-3a_bookworm_current_6.1.63_gnome_desktop but there was no signal in HDMI, I then flashed it with Armbian_22.05.0-trunk_Rk3318-box_jammy_current_5.15.35_xfce_desktop and Armbian_22.02.0-trunk_Rk3318-box_bullseye_edge_5.15.16_minimal, on both the image I was able to get the armbian running. The issue now I am facing is, in both the cases the WIFI is detected and SSIDs are listed but when I try to connect with password with router, it fails, I double checked if I am using the correct WIFI security. I tried connecting with hotspot on iPhone but having same issue, However if I enable "Maximise compatiblity" on iPhone settings, the WIFI connect, but is highly unstable and very slow, barely working. Attaching some screenshots of the board and output of /var/log/syslog
Edited by Raja J
Read the first post of the main thread about rk3318, there is an alternative firmware for your wifi you may want to try
