RSS Bot Posted December 25, 2023 Posted December 25, 2023 Bumps tj-actions/changed-files from 40 to 41. Release notes Sourced from tj-actions/changed-files's releases. v41 Changes in v41.0.1 What's Changed Upgraded to v41 by @tj-actions-bot in tj-actions/changed-files#1811 chore(deps): update dependency eslint-plugin-prettier to v5.1.2 by @renovate in tj-actions/changed-files#1813 fix: update characters escaped by safe output by @jackton1 in tj-actions/changed-files#1815 Full Changelog: https://github.com/tj-actions/changed-files/compare/v41...v41.0.1 Changes in v41.0.0 🔥 🔥 BREAKING CHANGE 🔥 🔥 A new safe_output input is now available to prevent outputting unsafe filename characters (Enabled by default). This would escape characters in the filename that could be used for command injection. [!NOTE] This can be disabled by setting the safe_output to false this comes with a recommendation to store all outputs generated in an environment variable first before using them. Example ... - name: Get changed files id: changed-files uses: tj-actions/changed-files@v40 with: safe_output: false # set to false because we are using an environment variable to store the output and avoid command injection. - name: List all added files env: ADDED_FILES: ${{ steps.changed-files.outputs.added_files }} run: | for file in "$ADDED_FILES"; do echo "$file was added" done ... What's Changed chore(deps): update typescript-eslint monorepo to v6.15.0 by @renovate in tj-actions/changed-files#1801 Upgraded to v40.2.3 by @tj-actions-bot in tj-actions/changed-files#1800 chore(deps): update dependency eslint-plugin-prettier to v5.1.0 by @renovate in tj-actions/changed-files#1802 chore(deps): lock file maintenance by @renovate in tj-actions/changed-files#1803 chore(deps): update dependency eslint-plugin-prettier to v5.1.1 by @renovate in tj-actions/changed-files#1804 fix: update safe output regex and the docs by @tj-actions-bot in tj-actions/changed-files#1805 Revert "chore(deps): update actions/download-artifact action to v4" by @jackton1 in tj-actions/changed-files#1806 Update README.md by @jackton1 in tj-actions/changed-files#1808 ... (truncated) Changelog Sourced from tj-actions/changed-files's changelog. Changelog 41.0.1 - (2023-12-24) 🐛 Bug Fixes Update characters escaped by safe output (#1815) (716b1e1) - (Tonye Jack) ⚙️ Miscellaneous Tasks deps: Update dependency eslint-plugin-prettier to v5.1.2 (7aaf10d) - (renovate[bot]) ⬆️ Upgrades Upgraded to v41 (#1811) Co-authored-by: jackton1 jackton1@users.noreply.github.com (cc08e17) - (tj-actions[bot]) 41.0.0 - (2023-12-23) 🐛 Bug Fixes Update safe output regex and the docs (#1805) (ff2f6e6) - (tj-actions[bot]) ⏪ Reverts Revert "chore(deps): update actions/download-artifact action to v4" (#1806) (4f573fe) - (Tonye Jack) 🔄 Update Update README.md (6e79d6e) - (Tonye Jack) Update README.md (d13ac19) - (Tonye Jack) Update README.md (bb89f97) - (Tonye Jack) Updated README.md (#1810) Co-authored-by: renovate[bot] (1864078) - (tj-actions[bot]) Update README.md (#1808) (47371c5) - (Tonye Jack) 📝 Other Merge pull request from GHSA-mcph-m25j-8j63 feat: add safe_output input enabled by default fix: migrate README to safe uses of interpolation ... (truncated) Commits 716b1e1 fix: update characters escaped by safe output (#1815) 7aaf10d chore(deps): update dependency eslint-plugin-prettier to v5.1.2 cc08e17 Upgraded to v41 (#1811) 6e79d6e Update README.md d13ac19 Update README.md bb89f97 Update README.md 1864078 Updated README.md (#1810) f495a03 chore(deps): lock file maintenance 47371c5 Update README.md (#1808) 4f573fe Revert "chore(deps): update actions/download-artifact action to v4" (#1806) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
