SES Posted December 27, 2023 Posted December 27, 2023 Hello! How to turn off Wi-Fi and Bluetooth devices to reduce power consumption? armbianmonitor -U -> result in attachment. Thank you. armbian-hardware-monitor.log 0 Quote
Gunjan Gupta Posted December 28, 2023 Posted December 28, 2023 Disable aw859a-wifi and aw859a-bluetooth services. For a more paranoid way, you can also add a dtoverlay to disable mmc1 something like /dts-v1/; /plugin/; &mmc1 { status = "disabled"; }; Save above to a file with .dts as extension and run "sudo armbian-add-overlay <filename>" 0 Quote
krrmbn Posted January 25, 2024 Posted January 25, 2024 Here is how I did it with my Orange Pi 3 LTS running the latest Armbian Ubuntu: # systemctl disable --now wpa_supplicant.service # systemctl mask wpa_supplicant.service # systemctl disable --now aw859a-bluetooth.service # sed -i '' '/sprdwl_ng/d' /etc/modules My typical load went from ~1 to ~0.01 to 0.1. 0 Quote
c0rnelius Posted January 26, 2024 Posted January 26, 2024 Or temporarily patch the driver until a better solution presents its self. diff --git a/drivers/net/wireless/uwe5622/unisocwifi/tx_msg.c b/drivers/net/wireless/uwe5622/unisocwifi/tx_msg.c index 40d51a7130d9..f1c356306c80 100644 --- a/drivers/net/wireless/uwe5622/unisocwifi/tx_msg.c +++ b/drivers/net/wireless/uwe5622/unisocwifi/tx_msg.c @@ -317,7 +317,15 @@ void sprdwl_dequeue_data_list(struct mbuf_t *head, int num) /* seam for tx_thread */ void tx_down(struct sprdwl_tx_msg *tx_msg) { - wait_for_completion(&tx_msg->tx_completed); + int ret; + while (1) { + ret = wait_for_completion_interruptible(&tx_msg->tx_completed); + if (ret == -ERESTARTSYS) { + continue; + } + + return; + } } void tx_up(struct sprdwl_tx_msg *tx_msg) -- 2.39.2 https://github.com/orangepi-xunlong/linux-orangepi/issues/57 0 Quote
