[Armbian build PR] - fixes failing 10Mbit built-in Ethernet -- https://armbian.atlassian.n…
…et/browse/AR-1904
Description
Using the Rock Pi S with 10mbps Ethernet connection is not possible. A connection is shown but data transmission is not possible.
Note that this patch is only for the "current" kernel. The "edge" kernel no longer boots RockPI-S.
Jira reference number AR-1904
How Has This Been Tested?
Built 23.05 Minimal image for RockPI-S
  • Verified Ethernet transfer @100Mbit/s initially
  • ethtool -s end0 advertise 3
  • Verified Ethernet transfer rate now only 10Mbit/s
  • ethtool -s end0 advertise f
  • Verified Ethernet transfer rate restored to 100Mbit/s
Bug was a regression first seen in the 5.15 Armbian kernel caused by a rewrite of speed setting for rk3308 in dwmc-rk.c that for some bizarre reason completely omitted the code needed to reprogram the MAC clock as appropriate for the selected Ethernet speed.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
