[Armbian build PR] - Fix rpi image creation broken since to #6087
Description
The raspberry pi images were broken since #6087 as armbian.list was no longer available to install the required packages. As the description for #6087 mentioned that the change was just to remove the dormant armbian.list.disabled file, this PR does the same simply by removing the file if its present after image-late.
How Has This Been Tested?
  • [X] Tested creating Raspberry pi images and also verifying that there is no leftover armbian.list.disabled file.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
