[Armbian build PR] - Hinlink H88k rockchip-rk3588 edge support
Description
Hinlink H88K mainline support with:
  • [x] one HDMI port output like other rk3588 boards such as rock5b(middle HDMI port )
  • [x] two 2.5G RTL8125 ethernet
  • [x] usb A ports
  • [x] audio jack output
  • [x] m.2 E slot wifi
  • [x] HS200 emmc
  • [x] TF card copied from rock5b should work, not tested
How Has This Been Tested?
  • [x] ./compile.sh BOARD=hinlink-h88k BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no COMPRESS_OUTPUTIMAGE=sha,gpg,xz DEB_COMPRESS=xz DESKTOP_APPGROUPS_SELECTED='3dsupport desktop_tools editors multimedia office remote_desktop' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy
  • [x] Board boots fine with on board emmc.
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
