RSS Bot Posted January 7, 2024 Posted January 7, 2024 Description Other devices could be added if whatever the regulator needed for UHS is enabled. Read perf def improved on the gnome disk benchmarks. Jira reference number [AR-9999] let's enable salva's UHS overlay for RK3399 tested on PBP with 2ghz with 64 gig samsung evo select i like using the yabs.sh fio benchmark for mixed r/w tests curl -sL yabs.sh | bash -s -- -i -g -n also did gnome disk utility read benchmark before kernel 6.6.10 yabs # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Jan 6 05:59:38 PM EST 2024 ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : Cortex-A53 Cortex-A72 CPU cores : 6 @ 1512.0000 2016.0000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.7 GiB Swap : 1.9 GiB Disk : 57.5 GiB Distro : Armbian 23.08.0-trunk sid Armbian 23.08.0-trunk sid Kernel : 6.6.10-edge-rockchip64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mmcblk1p1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.82 MB/s (457) | 8.12 MB/s (126) Write | 1.85 MB/s (463) | 8.51 MB/s (133) Total | 3.68 MB/s (920) | 16.63 MB/s (259) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 12.39 MB/s (24) | 12.48 MB/s (12) Write | 13.51 MB/s (26) | 13.74 MB/s (13) Total | 25.90 MB/s (50) | 26.23 MB/s (25) gnome disk utility read benchmark (just defaults) Cool got some tiny gains on everything but 4k block after UHS enabled 6.6.10 yabs # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Jan 6 06:05:48 PM EST 2024 ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Cortex-A53 Cortex-A72 CPU cores : 6 @ 1512.0000 2016.0000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.7 GiB Swap : 1.9 GiB Disk : 57.5 GiB Distro : Armbian 23.08.0-trunk sid Armbian 23.08.0-trunk sid Kernel : 6.6.10-edge-rockchip64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mmcblk1p1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.85 MB/s (464) | 8.81 MB/s (137) Write | 1.88 MB/s (471) | 9.32 MB/s (145) Total | 3.74 MB/s (935) | 18.14 MB/s (282) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 13.06 MB/s (25) | 13.64 MB/s (13) Write | 14.38 MB/s (28) | 15.23 MB/s (14) Total | 27.44 MB/s (53) | 28.87 MB/s (27) gnome disk utility read benchmark (just defaults) View the full article
