RSS Bot Posted January 8 Posted January 8 Description In several situations we need to have systemd-resolved installed and configured or we loose DNS. This happens in case of HA and most likely OMV too. As per documentation: systemd-resolved will work out of the box with a network manager using /etc/resolv.conf. No particular configuration is required since systemd-resolved will be detected by following the /etc/resolv.conf symlink. This is going to be the case with systemd-networkd, NetworkManager, and iwd. move DNS server set from Ubuntu specifics change switch to if and check for DISTRIBUTION instead of RELEASE detach bullseye so we can keep it operational without systemd-resolved change bullseye to EOS Install systemd-resolved by default to all variants Jira reference number AR-1657 How Has This Been Tested? [x] Made few images Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
