Bones558 Posted January 9 Share Posted January 9 I have a Logitech C920 webcam I am trying to use on my Radxa Zero. I'm running Armbian 23.11.1 Bookworm 6.1.63 64-bit. When I run v4l2-ctl -i /dev/video1 --list-formats to query the webcam, it errors out. VIDIOC_S_INPUT: failed: Inappropriate ioctl for device ioctl: VIDIOC_ENUM_FMT Type: Video Capture Multiplanar [0]: 'NM12' (Y/UV 4:2:0 (N-C)) It seems anything relying on v4l2 is also failing to work. Anyone have ideas of what the issue may be? Thanks! ---------------------- FYI...If I use this webcam on a RaspberryPi 4 running Bookworm, it produces the following output and all v4l2 work. Video input set to 0 (Input 1: Camera, ok) ioctl: VIDIOC_ENUM_FMT Type: Video Capture [0]: 'YUYV' (YUYV 4:2:2) [1]: 'H264' (H.264, compressed) [2]: 'MJPG' (Motion-JPEG, compressed) 0 Quote Link to comment Share on other sites More sharing options...
