SteveH Posted January 18, 2017 Posted January 18, 2017 Hello, I try to get WiFi P2P working on the Nano Pi Neo Air with a 4.x mainline kernel and so I tried the latest available nightly build "Armbian_5.24.170118_Nanopiair_Ubuntu_xenial_4.9.4.img" but I have problems to establish a connection. Does anybody have WiFi P2P working on the Nano PI Neo Air? The problem seems be a problem with the P2P_CLIENT interface creation at the brcmfmac driver. My P2P test peer is a Nexus 5 phone and I'am able to see the peer device using wpa_cli p2p_peers. But when I try to connect I get following driver error messages at the Kernel Log. [ 8.085540] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Jun 6 2014 14:50:39 version 7.10.226.49 ® FWID 01-8962686a [ 83.057486] brcmfmac: brcmf_do_escan: error (-110)[ 83.062334] brcmfmac: brcmf_cfg80211_scan: scan error (-110)[ 85.611612] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout[ 85.617463] brcmfmac: brcmf_p2p_tx_action_frame: sending action frame has failed[ 85.625002] brcmfmac: brcmf_p2p_send_action_frame: Failed to send Action Frame(retry 1)[ 88.171615] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout wpa_supplicant log: p2p-dev-wlan0: Control interface command 'P2P_CONNECT 36:fc:ef:a4:be:2c pbc'p2p-dev-wlan0: Determining shared radio frequencies (max len 1)p2p-dev-wlan0: Shared frequencies (len=0): completed iterationp2p-dev-wlan0: Shared frequencies (len=0): valid for P2Pp2p-dev-wlan0: Determining shared radio frequencies (max len 1)p2p-dev-wlan0: Shared frequencies (len=0): completed iterationp2p-dev-wlan0: P2P: num_unused_channels: 1P2P: Setup freqs: freq=0 num_MCC=1 shared_freqs=0 num_unused=1P2P: Current operating channels are not available for P2P. Try to use another channelP2P: Own frequency preference: 0 MHzP2P: Create a new interface p2p-wlan0-0 for the groupnl80211: Create interface iftype 8 (P2P_CLIENT)Failed to create interface p2p-wlan0-0: -110 (Connection timed out)P2P: Failed to create new group interfaceP2P: Failed to allocate a new interface for the groupwpa_supplicant is started as following: wpa_supplicant -B -iwlan0 -c/etc/p2p_supplicant.conf -f /var/log/wpa_supplicant.log -dd p2p_supplicant.conf: ctrl_interface=/var/run/wpa_supplicantupdate_config=1device_name=NANO-P2Pdevice_type=1-0050F204-1config_methods=virtual_push_button physical_display keypadp2p_go_intent=1country=USp2p_no_group_iface=1 Thank you, Steve
