RSS Bot Posted January 9 Posted January 9 This does not change the current boot order and requires additional hardware. Hardware used in my testing: BananaPi BPI-CM4IO Baseboard with BPI-CM4 Module Mini PCI-E PCI Express to SATA 3.0 Dual Ports Adapter Converter Hard Drive Extension Card https://a.co/d/0G679qW Kingston 120GB A400 SATA 3 2.5" Internal SSD https://a.co/d/fB2qf3r External power supply for Hard Drive 2.5" 3.5" https://www.ebay.com/itm/114620135743 bananapi: ~ $ lspci 00:00.0 PCI bridge: Synopsys, Inc. DWC_usb3 / PCIe bridge (rev 01) 01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) bananapi: ~ $ sudo blkid /dev/mmcblk1p1: LABEL="EMMC" UUID="67ea5c62-c9cb-498e-91ff-3e60d71bd1ab" BLOCK_SIZE="512" TYPE="xfs" PARTUUID="0a8751c2-01" /dev/sda2: LABEL="ROOTFS" UUID="39d23eae-ba3a-4b28-acba-8f45ff8eed1c" BLOCK_SIZE="512" TYPE="xfs" PARTUUID="e6053ca6-02" /dev/sda1: LABEL="BOOT" UUID="d540a625-98a8-4c73-a5a3-7a905d5bbb98" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="e6053ca6-01" /dev/zram0: UUID="ee6d34f4-fda2-4207-8dc9-b8a4b83cd759" TYPE="swap" bananapi: ~ $ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 111.8G 0 disk ├─sda1 8:1 0 508M 0 part /boot └─sda2 8:2 0 111.3G 0 part / mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.6G 0 part mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk zram0 253:0 0 1G 0 disk [SWAP] Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
