[Armbian build PR] - rockchip: update kernel configs
Description
Forgot to shift kernel configs for rockchip family when switching current to 6.6 and edge 6.7; done right now.
Curiously I noticed this after hitting "buggy" behaviour on rk322x board with several rcu_scheduler debug messages while board was under high load, vnstatd process was often at 100% cpu usage and reading /proc/net/dev file (which is a simple text file with some network interface stats) stalls vnstatd. Turning off eth0 interface solved the problem but of course it was not solution.
I shifted the kernel config, recompiled kernel 6.6 and this apparently solved the problem (maybe thanks to CONFIG_NEED_SRCU_NMI_SAFE=y ?)
If it is so, the consideration I make here is that using that using a kernel config that does not match the kernel version may, in some corner cases, be harmful for stability
How Has This Been Tested?
  • [x] Kernel deb packages compiled and tested on live rk322x system
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
