RSS Bot Posted January 13 Share Posted January 13 See the discussion in https://forum.armbian.com/topic/30074-helios64-armbian-2308-bookworm-issues-solved/page/3/#comment-179040 Description The Helios64-specific changes get moved to rockchip64, as https://github.com/armbian/build/blob/main/config/boards/helios64.csc#L3 says that it's not rk3399 anymore. How Has This Been Tested? See discussion in https://forum.armbian.com/topic/30074-helios64-armbian-2308-bookworm-issues-solved Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article Link to comment Share on other sites More sharing options...
Trillien Posted April 7 Share Posted April 7 Hi @prahal, I'm running Armbian_23.5.4_Helios64_bookworm_current_6.1.36 on my Helios64. In /etc/armbian-release, BOARDFAMILY was rk3399 As per your post, I manually changed BOARDFAMILY to rockchip64. $ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=helios64 BOARD_NAME="Helios64" BOARDFAMILY=rockchip64 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=173ed85 VERSION=23.08.0-trunk LINUXFAMILY=rockchip64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" BRANCH=current That's dirty, but that let me have access to the newest armbian package releases. Can you please advise whether you know a cleaner way to match to the new BOARDFAMILY for Helios64 and its rockchip processor? Link to comment Share on other sites More sharing options...
Deoptim Posted April 21 Share Posted April 21 (edited) deleted - offtopic Edited April 22 by Deoptim Link to comment Share on other sites More sharing options...
