RSS Bot Posted January 15, 2024 Posted January 15, 2024 Bumps actions/upload-artifact from 4.0.0 to 4.1.0. Release notes Sourced from actions/upload-artifact's releases. v4.1.0 What's Changed Add migrations docs by @robherley in actions/upload-artifact#482 Update README.md by @samuelwine in actions/upload-artifact#492 Support artifact-url output by @konradpabjan in actions/upload-artifact#496 Update readme to reflect new 500 artifact per job limit by @robherley in actions/upload-artifact#497 New Contributors @samuelwine made their first contribution in actions/upload-artifact#492 Full Changelog: https://github.com/actions/upload-artifact/compare/v4...v4.1.0 Commits 1eb3cb2 Merge pull request #497 from actions/robherley/update-readme-limit 8688a86 Update readme to reflect new artifact/job limit 73d8b66 Support artifact-url output (#496) c320f57 Update README.md (#492) cf8714c Merge pull request #482 from actions/robherley/add-migration-docs 7f16e37 add migrations docs 3530730 Merge pull request #468 from actions/robherley/misc-updates 6c139af update imports and old v4-beta references See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
