RSS Bot Posted January 20, 2024 Posted January 20, 2024 Description This change includes kernel patches to provide the following overlays when using armbian-config on the Orange Pi Zero 2 and Orange Pi Zero 3 boards. I2C IR USB OTG SPI UART These boards share very similar SOCs (RH616 / RH618), and the existing configuration that was also shared with the bigtreetech board did not function correctly for the Orange Pi Zero 2/3 boards, so the Zero 2/3 board overlay configuration was split out into its own files, and the board configurations updated to reference the new overlays. Note: The patches for these overlays have been added to the 6.1, 6.6 (current), and 6.7 (edge) patch directories but it appears the 6.1 code may not be used with the current configurations for these boards. Jira reference number [AR-9999] How Has This Been Tested? These updates have been tested with the following configurations [x] Zero 2 Current and Edge kernel with Debian userspace [ ] Zero 3 Current and Edge kernel with Debian userspace (current pending testing) The validation process at a high level Boot clean Armbian image and configure base configuration Launch armbian-config and turn on all Hardware overlays options for the board Reboot when prompted, and confirm that overlays apply correctly in early boot logs (serial connection) Confirm hardware devices are available in the OS Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
