Delphist52 Posted January 23 Share Posted January 23 Hello everyone. Please help me with the following problem. I have a Rock Pi 4b 1.4 (with SPI flash). I did the boot from the NVMe SSD using the image rkspi_loader-v20.11.2-trunk-v2.img according to the instructions. I installed Armbian 23.11 Jammy XFCE on NVMe SSD KingSpec NX 1TB. I’m using a power supply Baseus 65W GaN Pro (with PD). The system loads and works well. However, the system cannot reboot. When i click on reboot, the system starts to reboot and after the reset goes into a cyclic reboot. I need to turn off the power to reboot. What could be the problem and how to solve it? UART (Serial console) log: " " $&0 f@`B@@NF0f@`B@@NF 0f@`B@@NF@@@LN`b`N" " 0 "$`@@NN`0@b`@``@LFbpb`@H U-Boot TPL 2020.07-armbian (Dec 04 2020 - 22:10:39) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) Trying to boot from SPI NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPI Flash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Model: Radxa ROCK Pi 4B Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! "Synchronous Abort" handler, esr 0x96000210 elr: 000000000022d918 lr : 000000000022d8b4 (reloc) elr: 00000000f3f5a918 lr : 00000000f3f5a8b4 x0 : 00000000f8000000 x1 : 0000000000000001 x2 : 0000000000000000 x3 : 0000000000100000 x4 : 00000000f1f36b30 x5 : 0000000000100000 x6 : 0000000000000001 x7 : 00000000f3fcd888 x8 : 0000000000000000 x9 : 0000000000000008 x10: 00000000ffffffe8 x11: 0000000000000010 x12: 000000000000149c x13: 00000000f1f149fc x14: 00000000f1f15b20 x15: 0000000000000020 x16: 00000000f3f5a878 x17: 0000000000060001 x18: 00000000f1f26dc0 x19: 00000000f1f14970 x20: 0000000000000001 x21: 0000000000000000 x22: 0000000000010000 x23: 00000000f3fd37f8 x24: 0000000000010000 x25: 00000000f3fba3f2 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000f1f36a40 x29: 00000000f1f148d0 Code: 540000c1 350000a5 93407c05 f9400080 (b86068a0) Resetting CPU ... resetting ... U-Boot TPL 2020.07-armbian (Dec 04 2020 - 22:10:39) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) Trying to boot from SPI NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPI Flash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Model: Radxa ROCK Pi 4B Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! "Synchronous Abort" handler, esr 0x96000210 elr: 000000000022d918 lr : 000000000022d8b4 (reloc) elr: 00000000f3f5a918 lr : 00000000f3f5a8b4 x0 : 00000000f8000000 x1 : 0000000000000001 x2 : 0000000000000000 x3 : 0000000000100000 x4 : 00000000f1f36b30 x5 : 0000000000100000 x6 : 0000000000000001 x7 : 00000000f3fcd888 x8 : 0000000000000000 x9 : 0000000000000008 x10: 00000000ffffffe8 x11: 0000000000000010 x12: 000000000000149c x13: 00000000f1f149fc x14: 00000000f1f15b20 x15: 0000000000000020 x16: 00000000f3f5a878 x17: 0000000000060001 x18: 00000000f1f26dc0 x19: 00000000f1f14970 x20: 0000000000000001 x21: 0000000000000000 x22: 0000000000010000 x23: 00000000f3fd37f8 x24: 0000000000010000 x25: 00000000f3fba3f2 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000f1f36a40 x29: 00000000f1f148d0 Code: 540000c1 350000a5 93407c05 f9400080 (b86068a0) Resetting CPU ... resetting ... U-Boot TPL 2020.07-armbian (Dec 04 2020 - 22:10:39) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) Trying to boot from SPI NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: If lpddr4 need support multi frequency, INFO: please update loader! INFO: Current ctl index[0] freq=400MHz INFO: Current ctl index[1] freq=800MHz INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.07-armbian (Dec 04 2020 - 22:10:39 +0100) SoC: Rockchip rk3399 Reset cause: RST Model: Radxa ROCK Pi 4B DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPI Flash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Model: Radxa ROCK Pi 4B Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! "Synchronous Abort" handler, esr 0x96000210 elr: 000000000022d918 lr : 000000000022d8b4 (reloc) elr: 00000000f3f5a918 lr : 00000000f3f5a8b4 x0 : 00000000f8000000 x1 : 0000000000000001 x2 : 0000000000000000 x3 : 0000000000100000 x4 : 00000000f1f36b30 x5 : 0000000000100000 x6 : 0000000000000001 x7 : 00000000f3fcd888 x8 : 0000000000000000 x9 : 0000000000000008 x10: 00000000ffffffe8 x11: 0000000000000010 x12: 000000000000149c x13: 00000000f1f149fc x14: 00000000f1f15b20 x15: 0000000000000020 x16: 00000000f3f5a878 x17: 0000000000060001 x18: 00000000f1f26dc0 x19: 00000000f1f14970 x20: 0000000000000001 x21: 0000000000000000 x22: 0000000000010000 x23: 00000000f3fd37f8 x24: 0000000000010000 x25: 00000000f3fba3f2 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000f1f36a40 x29: 00000000f1f148d0 Code: 540000c1 350000a5 93407c05 f9400080 (b86068a0) Resetting CPU ... resetting ... 0 Quote Link to comment Share on other sites More sharing options...
Delphist52 Posted January 29 Author Share Posted January 29 It looks like the problem is in the SSD. I took another NVMe SSD (500 GB Samsung 980 mz-v8v500) and everything works on it and reboots without problems. 0 Quote Link to comment Share on other sites More sharing options...
