bonedaddy4538 Posted January 24, 2024 Posted January 24, 2024 (edited) On a fresh install from the website on kernel 6.1 bookworm/Jammy when rebooting the board a kernel panic occurs and the device will not boot unless power cycled. This was not the case even a few months ago on a 6.6 edge kernel. I also tried the current edge 6.7 kernel and the board wouldn't boot at all not that I expected it to. The board says 3308B on the chip(samsung memory) and ive also tried two different micro sd. Anyone else having this issue? Serial output is below of the relevant failure Quote [ OK ] Reached target reboot.target - System Reboot. [ 95.928742] Unable to handle kernel NULL pointer dereference at virtual address 000000000000013c [ 95.929580] Mem abort info: [ 95.929842] ESR = 0x0000000096000004 [ 95.930191] EC = 0x25: DABT (current EL), IL = 32 bits [ 95.930682] SET = 0, FnV = 0 [ 95.930969] EA = 0, S1PTW = 0 [ 95.931266] FSC = 0x04: level 0 translation fault [ 95.931799] Data abort info: [ 95.932072] ISV = 0, ISS = 0x00000004 [ 95.932427] CM = 0, WnR = 0 [ 95.932709] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000003ea2000 [ 95.933299] [000000000000013c] pgd=0000000000000000, p4d=0000000000000000 [ 95.933944] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP [ 95.934521] Modules linked in: sunrpc lz4hc lz4 hci_uart btqca btrtl btbcm btintel snd_soc_pcm5102a snd_soc_rk3308 snd_soc_simple_card snd_soc_rockchip_i2s_tdm bluetooth snd_soc_simple_card_utils rockchip_rng rng_core rfkill snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd soundcore cpufreq_dt zram binfmt_misc dm_mod ip_tables x_tables autofs4 realtek dwmac_rk stmmac_platform stmmac pcs_xpcs [ 95.938132] CPU: 3 PID: 1 Comm: systemd-shutdow Not tainted 6.1.63-current-rockchip64 #1 [ 95.938873] Hardware name: Radxa ROCK Pi S (DT) [ 95.939293] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 95.939937] pc : kobject_get+0x18/0xbc [ 95.940318] lr : device_shutdown+0xb4/0x260 [ 95.940723] sp : ffff800009d2bc20 [ 95.941032] x29: ffff800009d2bc20 x28: ffff000000588000 x27: 0000000000000000 [ 95.941716] x26: ffff8000094fa130 x25: 0000000000000008 x24: ffff800009c61050 [ 95.942396] x23: ffff000002c81090 x22: ffff800009cd3e18 x21: 0000000000000100 [ 95.943076] x20: ffff000003b0b888 x19: 0000000000000100 x18: ffffffffffffffff [ 95.943758] x17: 000000040044ffff x16: 00100072b5503510 x15: 000000000013c680 [ 95.944435] x14: 00000000000639c0 x13: ffff000005860300 x12: 0000000000000001 [ 95.945114] x11: 00000000ffffffff x10: ffff000007330420 x9 : ffff0000031cb828 [ 95.945794] x8 : ffff800009d2bb88 x7 : 0000000000000000 x6 : ffff000007330650 [ 95.946473] x5 : ffff8000089ec56c x4 : ffff8000089ec56c x3 : 0000000000000000 [ 95.947149] x2 : 0000000000000001 x1 : ffff800009b7acd8 x0 : 0000000000000100 [ 95.947828] Call trace: [ 95.948064] kobject_get+0x18/0xbc [ 95.948405] device_shutdown+0xb4/0x260 [ 95.948776] kernel_restart+0x40/0xa4 [ 95.949137] __do_sys_reboot+0x1e0/0x264 [ 95.949517] __arm64_sys_reboot+0x24/0x30 [ 95.949906] invoke_syscall+0x48/0x114 [ 95.950280] el0_svc_common.constprop.0+0x44/0xfc [ 95.950739] do_el0_svc+0x30/0xd0 [ 95.951071] el0_svc+0x2c/0x84 [ 95.951385] el0t_64_sync_handler+0xbc/0x140 [ 95.951801] el0t_64_sync+0x18c/0x190 [ 95.952174] Code: 910003fd f9000bf3 aa0003f3 b4000160 (3940f000) [ 95.952738] ---[ end trace 0000000000000000 ]--- [ 95.953228] note: systemd-shutdow[1] exited with preempt_count 1 [ 95.953813] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 95.954644] Kernel Offset: disabled [ 95.954969] CPU features: 0x00000,00000080,0000421b [ 95.955424] Memory Limit: none [ 95.955722] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]--- Thanks for anyone willing to look. Update: Reboot works fine on rockpi-s ordered more recently late 2023 with non-samsung ram module. I wonder if that is a reason. I will try the last 5.15 firmware created for this board and see if that works. Edited January 25, 2024 by bonedaddy4538 0 Quote
bonedaddy4538 Posted January 25, 2024 Author Posted January 25, 2024 After looking at some radxa forums there are certain batches of this v1.3 board with issues. You can tell right away by it not booting or from official firmware having this serial output only. Quote DDR Version V1.26 0 Quote
