Hello everybody, this is my very first post on armbian forum!
I wanted to give a try to armbian on my bananapi M1 so I'm running the Debian Jessie server version.
I formerly used both raspbian and bananian and always ran OpenVPN server in order to be able to connect home when I'm away.
This time I reconfigured the service from scratch following this guide: https://wiki.debian.org/OpenVPN
My problem is that I after the set up the daemon doesn't seem to start for real... :-/
The output of "service openvpn status" command report the service as running. On the other side, netstat on the server and telnet from a client on port 1194 act as the service isn't running. Even the tun0 interface doesn't appear on the "ifconfig -a" output.
I already try to restart the service and also to reboot.
Anybody has an idea or experienced something similar before?
Thank you all!
Hello again!
After some troubleshooting I noticed one of the certificate files had a 0 byte size. I repeated the whole procedure and now the service works with no problems.
So the debian wiki is good for armbian.
The "openvpn /etc/openvpn/server.conf" command helped in the troubleshooting.
You can mark the topic as solved.
Bye!
